Good to hear that you solved that problem. With regards to notchyness, it could be either normal synchro wear or your transmission fluid is the wrong viscosity. Which transmission fluid did you use when you replaced it back in June? CL9's use 75w80 transmission fluid. It is thinner than the normal manual transmission fluids that other car brands use.
