I thought they were 10kg front and 5kg rear.
but that's from the top of my head, I could be wrong.
found it on g2ic.com, was 263 lb/in F, 143 lb/in R . How is that calculated in kg/mm? or can someone please tell me what it is. Cheers
Yeah I thought it was a little less than that, close to the 4/3 mark, but remember that they are progressive front and rear from the factory.
Many aftermarket springs just simply aren't stiff. You just can't have super stiff springs and a super comfortable ride, which is a bit compromise in the mass market of coilovers.
Yes so? A stock DA9 spring might not reach 5kg/mm until it has nearly binded. And sorry, 5kg/mm on a honda double wishbone is NOT stiff.
