Prelude with Oil leak - should I buy?
Guys,
I'm looking at Prelude Si 1998 Manual with 117km on the clock for $10,5k.
The test drive went well so I applied for an independent vehicle check and this was the most concerning find:
- "Visually inspected motor of vehicle and oil leaks were found at top and bottom end of motor. Oil leaks were found around timing cover and also to engine sump. Oil was slightly dripping onto the floor. A slight intermittent noise was also heard to motor on start up. Note: Air filter box at bottom has been pulled out. Vehicle was road tested in a 50km/h speed limit zone.
NOTE: Oil leaks cannot be detected if they are cleaned before inspection. For a proper engine test, all engines should be cold."
Any advice is appreciated.
Thanks,
Paul
