Civic ek 1998 - how to fit aftermarket euro horns
MODEL: CIVIC 1998 VTI-R (EK4)
JOB DESCRIPTION: FIT AFTERMARKET HORNS
PARTS: HELLA TWIN HORN
http://farm4.static.flickr.com/3111/...1500f33eda.jpg
RECOMMENDED TOOLS:
*ELECTRICAL TAPE
*RACHET (1/4 OR 3/8) WITH EXTENSION
*8MM - 10MM SOCKETS
*SOLDERING IRON
*ELECTRICAL WIRE
*ELECTRICAL TERMINALS
*CABLE TIES
*TERMINAL CRIMPER
*WIRE STRIPPER
*CLIP REMOVAL TOOL
*PHILIPS HEAD SCREWDRIVER
*SCISSORS
http://farm3.static.flickr.com/2611/...720d964cc5.jpg
*REMOVE FRONT BUMPER
http://farm4.static.flickr.com/3660/...07183bc3da.jpg
REMOVE SIX PLASTIC CLIP SCREWS ON TOP OF THE GRILL
http://farm3.static.flickr.com/2668/...1ca94eb096.jpg
REMOVE TWO SCREWS UNDERNEATH THE BUMPER
http://farm4.static.flickr.com/3647/...f4199a2e98.jpg
REMOVE TWO SCREWS (LH+RH) UNDER THE WHEEL ARCH THAT CONNECTS THE BUMPER WITH THE FENDER
NOW REMOVE THE FRONT BUMPER AND THIS IS WHAT YOU SHOULD SEE
http://farm3.static.flickr.com/2012/...4a0e46e2af.jpg
*REMOVE OLD HORN AND FIT NEW HORNS
http://farm3.static.flickr.com/2164/...97a4d3caec.jpg
LOCATE OLD HORN AND UNPLUG THE ELECTRICAL CONNECTOR AND UNBOLT IT FROM THE MOUNT
*CREATE FOUR NEW ELECTRICAL WIRE WITH TERMINALS
http://farm3.static.flickr.com/2323/...beeee6722e.jpg
http://farm3.static.flickr.com/2461/...5b6e38e5e2.jpg
TWO GROUND WIRE
http://farm3.static.flickr.com/2524/...20b0939bc3.jpg
TWO SIGNAL WIRE
*SOLDER TWO SIGNAL WIRES INTO EXISTING HORN HARNESS
http://farm4.static.flickr.com/3388/...a9c50ac298.jpg
*FIND A GROUND POINT AND BOLT THE GROUND WIRES TO IT
http://farm4.static.flickr.com/3663/...f764e13750.jpg
*CONNECT THE SIGNAL AND GROUND WIRE TO EACH HORN
*MOUNT THE HORNS
*TEST THE HORNS BEFORE YOU REFIT THE BUMPER
*IF TESTING IS OK REFIT THE BUMPER IN THE REVERSE ORDER FROM THE PREVIOUS STEPS
*FINISHED
