engine movement
hey guys mite sound abit wierd..got a problem with my teggy, sometimes i put it into drive and bound to take off some times the engine is heaps loose.. it shakes.. sometimes even when i release smoothly has anyone had the same problem. . ive checked all my mounts and that.. there all in tact. im thinking of getting a torque damper kit.. do they make a difference.. cheers
Rubber bushings in your mounts are probably wearing out, not so easy to spot in a glance. I would recommend getting new engine mounts over a torque damper kit though, they do the same job but better
torque damper only works if your mounts are in good condition. otherwise the torque damper will take to much stress and have been known to break.
Are you sure your mounts are fine? I doubt the damper kit will fix your problem, if anything would just be a band-aid fix.
thanks guys .. i was looking at hasport mounts, are they any good..
Been covered plenty of times before, please search:
http://www.ozhonda.com/forum/showthr...unts-vibration
Hasports mounts are great, good quality and do the job fine. They will however create more in cabin vibration. You do have other options apart from Hasport mounts. See thread above.
cheers man .. cause a ive heard ov them but never actually took notice.. so engine mounts make a big difference aye
when i get the hasport mounts would be stop my wheel hops most of the time.. cause man that gives me the shits sometimes haha.. and also these silka fix.. they any good.. or should i go straight to new mounts.. cheers
wheels hops wont stop because of your mounts. get a traction bar.
Mounts do help with hop. You can even get hop with Traction bars installed. Doesn't solve anything, it just helps to improve hop.
