debadging the Civic EK1 1999
So today I decided it is finally time to debadge my civic EK1.
I will be leaving the H badges because they require a lot of work:thumbdwn: due to the holes that will be left when debadged, and just tackling the 'civic' badge to begin with!
First of all! Here's a BEFORE photo
https://fbcdn-sphotos-d-a.akamaihd.n...42542031_o.jpg
First: Applying boiling water
This will help loosen up the adhesives behind the badge and make it easier to remove while also reducing the risk of damaging the pain
https://fbcdn-sphotos-f-a.akamaihd.n...99046678_o.jpg
Secondly: You can use various tools but my choice of weapon will be some dental floss!
start working at one end and move the floss back and forth dividing the adhesive holding up the badge. pour more hot water in the seams to make it easier.
https://fbcdn-sphotos-a-a.akamaihd.n...49497971_o.jpg
THE BADGE IS OFF:cool::cool::cool:
https://fbcdn-sphotos-g-a.akamaihd.n...83994981_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...52174658_n.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...05173112_n.jpg
As you can see there is some adhesive left on the body.
https://fbcdn-sphotos-e-a.akamaihd.n...29341222_n.jpg
You will require: WD-40, Orange Power (Or any other adhesive remover alternative), A rag or micro fibre cloth.
https://fbcdn-sphotos-e-a.akamaihd.n...23605561_n.jpg
Spray some WD-40 on it and let is soak up for a few minutes.
After a couple of minutes use an old or unused card and start scraping away!
https://fbcdn-sphotos-h-a.akamaihd.n...66036282_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...99770800_n.jpg
After I had scraped off most of the adhesive I could still see an outline of sticky glue stuff. This is where the Orange Power comes in.
Dab some orange power on to a cloth and spread it over the surface area. After a couple seconds, rub it off with a cloth and warm/hot water
https://fbcdn-sphotos-c-a.akamaihd.n...94393259_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...38726821_n.jpg
The finished Product!
You can still see a faint outline of the badge, nothing some T Cut and polish and fix
https://fbcdn-sphotos-f-a.akamaihd.n...06002801_n.jpg
The Badge now proudly sits on my desk wall :wave:
https://fbcdn-sphotos-h-a.akamaihd.n...74115632_n.jpg
Thanks for tuning in :) Leave a comment!
A good buff should get that outline out. I was lucky enough to get my badges removed when mine was at the smashies.
Looks a heap better debadged
