Originally Posted by
A-man
He is right about the facebook pages and forums. I rarely come on here anymore, mainly because its too much effort to siphon through all the BS and just get the info.
What 91-type R is saying is the Fuel pump is staying on with just the ignition on which isn't correct. The ignition on should allow the fuel pump to switch on for 5 seconds and the ecu light will switch off then when cranking the fuel pump will switch back on.
It sounds like maybe a bad contact on the main relay or possibly ecu related?
What ecu are you running?
