B16A2 OEM Fuel Injectors Technical Specs??
Hi Folks,
im looking into upgrading my B16A2 OEM injectors to suit my future applications,
though i will need the following technical specs/parameters before i can proceed with a tune on my PFC.
Does anyone know what the technical specs of the below?
Standard OBD2B OEM B16A2 Injectors (Top Feed - Saturated/High Impedence)
Injector Size (??cc/min):
Injector Latency/Lag (?.???/msec):
anyone know the above?
According to Hondata tech page;
"Honda usually runs their injectors to 100% duty cycle at redline. They appear to adjust the fuel pressure to achieve this. A good example is the early B16A and B18C engines. Both have 240cc injectors, but the B16A has 38 lbs fuel pressure "
38lbs approx 30-35psi fuel pressure??
Full statement here: http://www.hondata.com/techduty.html
Anyone know if this is accurate? does anyone have concrete evidence or the tech specs?
cheers!
M
