CSF Racing Full size K swap radiator
CSF manufactures the most advanced and efficient radiator cores in the industry by using innovative tube and fin technologies with industry leading testing methods to maximize airflow and heat dissipation. Unlike a regular oval shape “O” type radiator tube, CSF uses a specially engineered tube in a shape of a “B”.
These “B-tubes” are carefully formed and then brazed over the seam to seal.
CSF is able to use thinner and lighter aluminum material (better cooling efficiency) because this design is actually stronger than normal “O” shape tubes that are welded.
CSF aims to lead the cooling systems industry by introducing new technologies and manufacturing processes that allows us to be on the cutting edge of heat transfer innovation.
$595 incl GST
http://farm6.staticflickr.com/5529/1...6be71659_o.jpg
