Originally Posted by
Beat
I am in the middle of a full brake upgrade. I am biasing my braking a little to the rear as my rear tyres are 195/45/15 and my front 165/55/14
Rear
I have fitted this to the rear of my daily drive and all good.
S2000 calipers 13CLP15S
Civic FD 2006 caliper mounts.
DBA2502 rotors 260mm diameter, 48mm high, 61mm centre hole, 4x100pcd, solid.
Im waiting more aggressive rear pad EBC yellow stuff.
The hand brake cable has the wrong end. I used a 5mm bolt to replace the pin, it works well so now I will machine a couple of SS pin up.
All this bolts up without any modification. Hydraulic lines bolt up no problems.
Front
On the bench I have mounted 2004 GD Jazz rotor & caliper which bolt up to the Beat hub without modification. (only the edge of the dust shield needs flattening)
DBA2504 rotor 240mm diameter, 39mm high, 61mm centre hole,4x100pcd, vented
Caliper 15CL13VN
Im looking for a set of JDM Honda Fit front brakes (231mm rotor) but will try the Jazz 240mm soon
