As I said before, whiteline end links are shit. Jdmyard sell asr end links. Give them a try.
No worries Drifter - that wasn't directed at you. OP has been given a few options throughout the thread, but seems to be listening selectively. The answers are all in the thread, yet there still seems to be a problem.
Are the asr ones longer than oem?
They are adjustable, so I'd gamble they can be. Check with jdmyard though if you're unsure
It makes sense though. Aftermarket swaybar needing aftermarket end links due to it being much thicker
Alight Ill give them a try. Thanks
Yes they are adjustable. I have them in the front and back of my EK4. The OEM EK4 rear ones are much longer than the OEM front, and the ASR's work fine in both locations.
http://www.jdmyard.com/index.php?rou...product_id=609
Not the cheapest option but if end link length is the only problem you have, then these will fix it. If the bar is poorly shaped, then end links may not fix your problem.
ASR's also come with different length spacers to allow you a bit more freedom with spacing the links away from the bar. This might just be enough to help clearance issues. Just check the contents of the box with the parts manifest. One of my kits was missing a pair of the thicker spacers, and some bolts. this was quickly sorted and they sent me the right bits.
I finally bought some asr end links from jdmyard and there is no more hitting. The front is noticeably stiffer as well
post some pics
You can see where it was hitting the control arm now there's plenty of clearance
