Well I’ve done a few drives in it now and it has improved quite a bit. Still not perfect but very good.
Well a new IAVC unit from Honda at a scary price has sorted it out totally. The old unit was dicey when the air cond was running.
Hi fellas, it seems the problem has returned. Certainly scratching my head now. I even went to the trouble of replacing the oxygen sensor in the exhaust.
Can anyone suggest where else to look?
It’s in the warm up phase of a cold start. Once the engine is warm it’s fine. When the engine is dead cold it’s fine too. It’s just as it gets up to operating temperature.
sounds like an idle stepper issue or maybe there is a vacuum leak somewhere and once everything heats and expands it seals to the point it doesnt affect the idle? try making a vacuum tester and connect to the throttle pressurize it and listen for air leaks in the intake gasket etc, use soapy water to look for bubbles. Make sure you do it with a cold engine to replicate when the car idles poorly.
have you tried turning it off and on again
I can’t say I’ve tried but once you restart after a stall, it just jumps straight back up to a healthy idle.
Hey fellas just a question on Ryco oil filters. One catalogue shows me a Z79A and another shows me Z411?
For a B18C7?
