Looking on the Bendix website, it says DB1515 for my 2007 CL9, but I rang up Repco and they say it's DB1393.
I'm confused. Which is the right one for the CL9 2007 model?
My '04 is DB1393 and I thought they were the same as the '07.
Same as mine from burson
Just called up Bendix and they say for an 07 model Accord Euro, it's DB1515 for the fronts. So I am just gonna grab a set of those off eBay which are $30 to $40 cheaper than Repco, SCA or Burson.
Will update when I get them and attempt to change them over.
I can supply genuine ones at close to half the price from dealers if interested.
Thanks, PM sent.
So I swapped the front Honda pads the other day with the Bendix DB1515 on my 2007 CL9. They are not exactly the same shape as the Honda OEM ones.
http://www.bendix.com.au/sites/defau...1515-Inner.gif
The two ridges at the top of the pad are wider apart than the Honda OEM ones. This presents a slight problem for the inner pad and the shims that go onto them.
The inner pad has two metal shims. The 1st shim covers most of the surface area on the back of the pad. This shim fits perfectly.
The 2nd shim is smaller in width (it covers the area of where the brake piston pushes onto the brake pad). This 2nd shim has two tabs on the top to clamp onto the pad and because the DB1515 pads have the ridges wider than the OEM one, it obstructs the tabs on the 2nd shim from clamping on. I had to bend the tabs back slightly for them to go on, but they are not clamped on tight.
Not sure if this poses a real problem or not?
Wish I had taken photos, but I was pretty annoyed at the time and wasn't really thinking about this thread.
A bit disappointed with Bendix and their online catalogue search result for my 2007 Euro.
:thumbdwn:
Sure it wasn't the DB1393 pads that may have been required?
http://www.bendix.com.au/sites/defau...1393-Inner.gif
It may be that while it mentions 2003-2005 they may still mean all CL9 models, while the 2006 onwards may have been directed towards the CU2 model? Might be an error in the catalogue
Funnily enough when I looked up google for CL9 brake pads it picked up another catalogue result:
http://www.bendix.com.au/catalogue/7821
DB1391
http://www.bendix.com.au/sites/defau...1391-Inner.gif
The box for my 1393 says its compatible with 2007 models.
It's definitely not DB1391. The Honda OEM ones look more like the 1393/1515.
Got an email reply from Bendix to say they are gonna check and verify their catalogue.
I will get the 1393 next time.
I've used both before (under a different brand). The correct ones are DB1393, which I am using again now. I had switched from the DB1393 shape to DB1515 a few years ago. When I installed the DB1515, one of the shims would not fit properly because of the two protrusions at the top of the pad. As a result, I had to bend the shims slightly. It still fitted and worked for a few years, but when the pad reached about 1.5mm of thickness, you would get a vibration under hard braking. I tested by switching back to my old DB1393 pads (didn't throw them out, I'm a hoarder) which was about the same thickness as the 1.5mm DB1515 and the vibration went away.
So, go for the DB1393.
Thanks aaronng. Good to know that I can still safely use them for an extended period.
Just got another email reply from Bendix saying that "the Bendix on-line catalogue has now been modified to remove the reference to DB1515 for July 2006 - May 2008 Honda Accord Euro".
DB1393 is now officially the front pads for all CL9 models.
I know this has been answered, it is definitely DB1393.
Just wanted to add that after much confusion I just installed Brembo front pads on a CL9. Many said (including Brembo Australia reps - admittedly they specialise in racing not a bog standard CL9!!) that there was no Brembo pads for a CL9. After lots of research (I landed on this thread as part of my research), and comparing diagrams online, and then taking a decent punt, I found some pads from a guy on gumtree who had bought them by error from the U.S. Installed the Brembo P28034N pads. Slotted in perfectly. Nice soft ceramic brakes and just waiting for them to bed in so that I can really test them out. The P28034 is apparently the same as P28034N. I believe 'N' just is the North America version - Happy to be corrected on that if it isnt the case.
