Bendix Synthetic Lubricant
Bendix Ceramic High Performance Synthetic Lubricant
Specially formulated from pure synthetic base oils and treated with the latest rust, oxidation and anti-wear additives to provide lasting protection against friction, wear and corrosion.
It is fortified with a high concentration of a unique, high temperature ceramic boundary lubricant that will stay in place and protect at extreme temperatures from -50°C to over 1650°C. while providing protection against dirt, corrosion and uneven pad wear.
http://www.bendix.com.au/sites/defau...ube-bottle.jpg
Synthetic Lubricant
Bendix Ceramic High Performance Synthetic Lubricant was designed to be compatible with most plastics and rubbers, especially ethylene propylene rubber (EPDM, EP or EPT) commonly used in Disc Brake Caliper systems. The distinctive Blue colour makes it easy to identify during and after application. For MSDS, TDS and approvals please visit bendix.com.au or bendix.co.nz.
When do I use Bendix Lubricant?
Every single brake pad replacement or brake shoe change
Should be applied to caliper hardware, pins, slides & bushes to ensure smooth operation
metal to metal contact areas
metal to rubber contact areas
backing plates of brake pads or brake shoes
between shim and backplate of brake pad
Where do I use Bendix Lubricant?
It can be used on seals of Disc Brake caliper assemblies, all moving caliper hardware, rubber components, backing plates, shims and Brake Shoe assemblies.
Designed as a high performance problem solving, anti-wear and anti-corrosion lubricant. Bendix Ceramic High Performance Synthetic Lubricant is a heavy solids based, pure synthetic, dry-film, boundary lubricant it is a superior noise dampening compound that will last the life of the brake pads and shoes thus reducing customer comebacks resulting from noise complaints from other braking components.
How much do I use?
One 6 gram sachet is sufficient to do 1 front or rear brake job.
http://www.bendix.com.au/sites/defau...ube-sachet.jpg
For more info on BENDIX product visit : http://www.bendix.com.au/
