Anti-Freeze or Coolant?
http://i762.photobucket.com/albums/x...t/coolant1.png
A running engine typically converts only one third of the energy from combustion into usable work to drive the car. The rest is converted into heat, and is enough to heat a large house in winter. That’s a lot of energy!
While engines are becoming smaller and more efficient, they are still generating extreme amounts of heat, and car body designs which focus on maximizing aerodynamic performance means less and less air is directed to your engine to cool it. That’s where engine anti-freeze/coolants come in to the picture.
Knowing what you need is important for getting the most out of your cooling system. So, do you need an anti-freeze or coolant?! You will find that almost all products on the auto parts store shelf are in fact both of those – an anti-freeze and coolant. Technically they are more of an anti-freeze than a coolant. More on that shortly.
For an engine anti-freeze/coolant to be effective, it should:
• Have excellent heat transfer characteristics;
• Possess a higher boiling point and lower freezing point compared to water;
• Resist foaming;
• Protect against corrosion caused by electrolysis;
• Be compatible with the materials in your cooling system;
• Work in the environment in which the engine is used;
• Be chemically stable.
The two main glycols used in engine coolants are ethylene glycol and propylene glycol. These additives, when mixed with water, help to lower its freezing point and raise its boiling point. This means that the anti-freeze/coolant won’t freeze when in extremely cold weather, and won’t boil under operating conditions, as this reduces its heat transfer abilities. Modern automotive engines typically run close to the boiling point of water. Anywhere between 85°C and 95°C.
In addition, additives are included to prevent corrosion and rust, and the formation of scales in the cooling system. The three main types of additives are: conventional inorganic; organic or; a hybrid mix of both, depending upon the characteristics required for a particular application.
Motul offers a range of engine coolants and additives for almost every vehicles.
The Motul Inugel Expert and Inugel Optimal line of ready-to-use and concentrate (Ultra)engine coolants provide great cooling properties and protection for your engine.
http://i762.photobucket.com/albums/x...t/coolant2.png
As seen here above, by increasing the ration of anti-freeze/coolant from 33% to 60% does very little to the boiling point but dramatically reduces your freezing point.
For Australia’s climate, there is no need to go above a mixing ratio of 33% if you use a concentrate product. The Motul Ready-To-Use anti-freeze/coolants are mixed at a ratio of 45% as this is considered globally universal in almost all climates. It should be noted that mixing at a ratio in excess of 50% in Australia’s climate will cause corrosion to the cooling system of your car. This would include your transmission heat exchanger if your car has one mounted in the radiator which could end up with transmission failure.
Using either Motul’s Ready-To-Use or Concentrate anti-freeze/coolants will provide you with reliable ongoing protection in Australia extreme climate!
http://i762.photobucket.com/albums/x...t/coolant3.pnghttp://i762.photobucket.com/albums/x...t/coolant4.png
Inugel Expert is a popular coolant based upon monoethyleneglycol, using hybrid additive technology. Inugel Expert is a Ready-To-Use anti-freeze/coolant and is recommended for all cooling systems for a range of applications including passenger vehicles, construction and agriculture machinery, ships, or in stationary engines. Motul recommends a complete cooling system flush prior to use to ensure the best results.
http://i762.photobucket.com/albums/x...t/coolant5.pnghttp://i762.photobucket.com/albums/x...t/coolant6.png
Inugel Expert Ultra is a concentrated antifreeze made to be mixed with demineralised water at the recommended ratio.It protects your cooling system from freezing and metallic parts from corrosion, whilst not affecting any rubber or plastic parts. And like the Ready-To-Use product, Inugel Expert Ultra is recommended for all cooling systems for a range of applications including passenger vehicles, construction and agriculture machinery, ships, or in stationary engines. Motul recommends a complete cooling system flush prior to use to ensure the best results.
http://i762.photobucket.com/albums/x...t/coolant7.pnghttp://i762.photobucket.com/albums/x...t/coolant8.png
Inugel Optimal’s Organic Acid Technology(OAT) reduces the operating temperature of your engine to maintain full power, whilst anti-scaling and anti-corrosion additives provide long-lasting protection throughout the cooling system. Plus it’s Ready-To-Use mixed @ 45% with demineralised water, so be sure to not add any water.
Recommended for all cooling systems for a range of applications including passenger vehicles, construction and agriculture machinery, ships, or in stationary engines. Motul recommends a complete cooling system flush prior to use to ensure the best results.
http://i762.photobucket.com/albums/x...t/coolant9.pnghttp://i762.photobucket.com/albums/x.../coolant10.png
Inugel Optimal Ultra is a concentrated antifreeze/coolant utilising OAT technology that should be mixed with demineralised water for use as a cooling fluid. The organic technology provides anti-corrosion properties that remain at high temperatures and for long periods, as the low corrosion inhibitors consumption allows extended drain intervals.
http://i762.photobucket.com/albums/x.../coolant11.png
MoCool is Motul’s concentrated cooling fluid, which is designed to be mixed with distilled water at 5% (20:1) in your cooling system to reduce engine temperatures by up to 15°C (30°F) and provide greater thermal exchange. It also protects your cooling system against corrosion, even in high temperatures and across long periods of time, as well as preventing cavitation (which causes significant mechanical wear) from occurring in your water pump. And, of course, it is friendly with the seals, rubber hoses and plastic components in your car’s cooling system.
Remember that to maintain effectiveness, your engine coolant should be changed at regular intervals as the additives in the coolant will age and deteriorate over time.
It’s not recommended to mix your Motul coolants with other coolant types as changing the chemical balance in the cooling system can adversely affect cooling performance.
For more information on the full range of Motul Anti-freeze/Coolants visit: https://www.motul.com/au/en/products/oils-lubricants?f[application]=147&f[range]=25
We’re here to help!
If you’d like some tips on how to read our product labels or maybe you’re wondering which is the best type of anti-freeze/coolant is for your car? Send us a PM!
If you have any questions about any of our products please feel free to get in contact with us.
