I am after a scanner that I want to do simple task such as pull codes and reseting code, etc.
I heard some people suggest ELM with iphone app which I found on ebay for cheap <$20.
Have anyone use them ?
Any suggestion for a reasonable $ scanner ?
ELM with the respective smartphone application does the job perfectly
Do you have this or use this before.
I have. It works.
Total cost including buying a paid ver of app Under $30 bucks I think.
Works okay. Slight lag on data cos Bluetooth speed.
Well worth, mech wants $80 per scan.
PS: if your from syd, you can use mine. It sits there collecting dust anyways.
you can still use the paper clip to check for codes with Honda's with OBDII ports
