The yanks also had a choice of a B17A. A DOHC VTEC block.
The second gen or "LS" Integra ran from 89-93, producing 130HP.
i believe only the 89-90 model produced 130hp and the 91-93 upgrade produced 140hp with stronger internals ...Quote:
Originally Posted by Chronos
89 to 91 tegs ran the b18a, at 130hp (96kw) the 92-93 had 140hp this is for the Aust spec cars difference bettween the two was only in the manifolds and ECU. In America they also had the GSR which ran a b17a, Basically just a stroked b16. in japan they also had the b16a, zc, and possibly also a d series single cammer. In Australia we only got the DA9 or LS model which came with all options including A/C and sunroof but ABS only on the updated 92-93 spec. (optional only?) the update model also had different steering wheel and front and rear bumpers. Also if anyone knows who owns the grey 4 door in Adelaide i would love to see your car close up and where is it from? 4 doors were never sold in Australia. oh yeah, the Aus spec 2nd gen teg weighed 1122kg. :)
Hows about some info on the LS? (redteg?)
Still waiting! :)Quote:
Originally Posted by wynode
found some info on the LS from carsales.com.au
Quick Info HONDA INTEGRA LS
Price $32,990 (back in 90-93)
Body 2 door Liftback
Transmission 5 speed Manual
Fuel Type Petrol
Release Date 1992
Segment Sports
Introduction HONDA INTEGRA
Country of origin Japan
Introduction
Dimensions HONDA INTEGRA
Length (mm) 4390
Width (mm) 1710
Height (mm) 1325
Wheelbase (mm) 2550
Track - front (mm) 1475
Track - rear (mm) 1475
Weights & Capacities HONDA INTEGRA
Kerb mass (kg) 1122
Body HONDA INTEGRA
VIN sample JHMDA93500S12346
Engine HONDA INTEGRA
Engine code B18A1
Engine location Front
Engine orientation Transverse
Engine description Four cylinders, in-line, belt-driven DOHC, four valves per cylinder, cross-flow head.
Capacity (cm3) 1834
Fuel system type PFI
Maximum power 103kW @ 6300rpm
Maximum torque 170Nm @ 5000rpm
Cylinders 4cyl
Valve train DOHC
Valves per cylinder 4v
Compression ratio 9.2:1
City 8.5
Highway 7.2
Drivetrain HONDA INTEGRA
Final drive location Front
Transmission description Five speed manual
Final drive ratio 4.26:1
Tyres & Rims HONDA INTEGRA
Front tyre description 195/60 R14 85H
Front rim description 5.5JJx14
Rim material Alloy
Warranty / Service HONDA INTEGRA
Warranty - description 3 yr, 80,000 km. 6 yr on corrosion
Major service interval (km) 10,000 km or 6 months.
and the link:
http://www.carsales.com.au/pls/carsales/!cs_content.research_specs?vehicle_code=19931116.0 9:05:26&sort_type=&current_rec=5&make_ name=HONDA&model_name=INTEGRA&year_min=199 0&year_max=1993
um
i have a friend who's civic EG vtir was in automatic...
Take a pic of the car + engine bay + auto shifter and I will belive you :)Quote:
Originally Posted by enoch
he meant a eg vti
Then he should say so :)Quote:
Originally Posted by gelo
wheres the rating for the integra ls ???
hehehehehe
