would putting a jdm B18c ITR engine into my em1 be a straight bolt on ????
if not what will be needed ?
can anyone guide me through what needs to be done :D tyyy
engine mounts
wiring looms
engine mount brackets
What needs to be done :
Get cash
Buy half cut
Take half cut to mechanic or at home
remove old engine out of car and half cut
install engine from half cut into car
Test
Take to mechanic to blue slip
Report to RTA
GGKKTHXBYE...WELCOME ABOURD !!
But in case you don't know hwo to google took me 5 secs to find something online :
http://www.clubcivic.com/board/showthread.php?t=75435
http://www.google.com.au/url?q=http:...-VrxoTHluw9jeQ
http://honda-tech.com/showthread.php?t=2354020
you will only to get a long block b18cr motor, as you can use everything from your em1
pretty much take out your motor and reuse your engine loom and use the rest of your b16a parts
all you will need is a obd2a to obd2b conversion harness to run a b18cr ecu or suitable aftermarket ecu
make sure you do clutch, bearings, gaskets, timing belt, etc at the same time
thanks for quick ass replies :)
you are welcome abourd ozhonda
