HOW TO: Fix Your Slow or Mis-aligned Power Windows (EG Civic)
Aim: To improve slow power windows and adjust alignment. This is quite a common problem with early model Hondas, such as ED, EG, EK and DC2's.
Required:
-Ratchet
-10mm socket
-Silicone Spray
-Phillips Head Screwdriver
-Rags
-Warm soapy water
-Old toothbrush
Steps:
1. Remove Door Trim. Unscrew P/W switch and handle surround. Pretty straight forward.
2. Remove Plastic Cover and Speaker. May need to unclip wiring depending on condition of your plastic cover. Also need to unscrew P/W switch bracket first, 2 screws.
http://img193.imageshack.us/img193/9610/img1110vz.jpg
3. Put the P/W switch back in and wind the window down.
4. Remove the Window by loosening 2 bolts.
http://img826.imageshack.us/img826/7620/img1111bolt.jpg http://img85.imageshack.us/img85/2279/img1112bolt.jpg
5. Slide the Window out on an angle, back angled up. Put it down out of the way in a safe place.
6. Remove the Glass Run Channel. Put your handle inside the door and start at the back, lift the rubber channel out of the bracket and pull it out slowly. Take care around the corners and take your time, it just pop out of the grooves. This is what it looks like when removed.
http://img716.imageshack.us/img716/4...13glassrun.jpg
7. Clean the Glass Run Channel. The edges of the window slides along this rubber channel. The culprit for slow Power Windows is usually caused by friction in the channel, i.e. dirt and debris inside the groove of this rubber channel. Clean out the inner groove with warm soapy water and a toothbrush. Or you can always go out and buy a new one.
Once clean hang it outside to dry.
8. Remove and Clean Regulator. This step is optional. While we have the door apart might as well go ahead and take out the regulator to clean and grease it. Remove 6 bolts and 1 plug then slide out through big oval hole to take out regulator. Also mark the Roller Guide Mounting bolt to keep the original adjustment.
http://img59.imageshack.us/img59/4451/img1117bolt.jpg
http://img854.imageshack.us/img854/6296/img1114bolt.jpg
9. Lay it down and clean all the tracks. Grease all the rollers and teeth.
http://img703.imageshack.us/img703/7...1118grease.jpg
10. Reinstall Glass Run Channel. Make sure it's dry and lubricate inner groove with some Silicone spray first. I started at the top back edge and worked my way around. Very important to get it to sit right in the groove of the door frame. Stick your head in and make sure it's sitting straight inside the channel brackets inside the door.
http://img525.imageshack.us/img525/5237/img1120mc.jpg
http://img28.imageshack.us/img28/2013/img1122vj.jpg
11. Reinstall Regulator. Reverse of removal. Just slide it back in and snug up the 6 bolts. Make sure the Roller Guide Mounting bolt is tightened back in the same place. If your window was dropping at the front when raised all the way up (like mine) then you can adjust this Roller Guide bolt down. If you adjust it down it will raise the front of the window up to be level. Also make sure you tighten all bolts back up and ensure the Glass Run Channel brackets are bolted down. Might sound weird but mine was missing a bolt there and the regulator bolts were loose causing my windows to go out of whack.
12. Reinstall Window. You can clean it before installing, especially on the edges. Reinstall is reverse of removal, just slide it back in front end first and line the 2 bolts up and tighten. Make sure it's sitting in the groove of the Run Channel. Test the window and make sure it operates smoothly.
13. Reinstall Plastic Cover. Reinstall Speaker. Put all wiring back in. Re-fit Door Trim, etc.
http://img856.imageshack.us/img856/7118/img1126a.jpg
http://img268.imageshack.us/img268/8076/img1124s.jpg
Other comments
Lubricate Run Channels every once in a while.
If your window is still slow:
1. Your P/W motor is probably on the way out. You can cause premature wear if you keep using your power windows when the rubber channel is clogged up.
2. You need a new Glass Run Channel, old one too worn out. Apparently there is a smooth coating on this rubber channel that gets worn out over time from opening and closing the window repeatedly
If your window keeps popping off the track:
1. Regulator bent
2. Glass run Channel bracket bent / not aligned.
3. Rubber Glass run Channel not properly snugged in or getting distorted when Windows being operated.
