Just curios are there any downsides of getting the cross drilled one? I wouldn’t mind paying an extra bit for looks… Wouldn’t it last longer as well?
Cross drilled are more susceptible to cracking between drill holes and are known to warp faster
I am looking to replace my front rotors on the CL9. Is the diameter 288mm or 300mm? Because both are coming up...
I believe the front rotors are 300mm, but can I get someone else to also confirm this…
i get all my brake gear from these guys ....
http://gslrallysport.com/au/
i use DBA 4000 T3 slotted rotors + Remsa pads + PMU Fluid on all of my cars =)
I got my DBA 4000 T3 rotors from ABR Parts.
Free shipping too!
http://abrparts.com.au/index.php?id_...roller=product
nope - almost no dust - less than the OEM spec ones that were on before
what rotors are you using? - and did you use a good amount of brake cleaning fluid when you installed them?
i have PMU (project MJU) type-NS pads and DBA normal slot rotors on my civic - and i find that the remsa/T3 slot combination is waaaay better
the PMU/normal slot combo isnt too bad but you have to get them red hot for them to even be remotely useful lol
i put HEL brake lines on the civic with the intention to put them on all of my cars
i will never buy HEL again - the fitment was disgustingly poor - i had to modify them alot to make them fit
the male/female fittings were terrible and i had to use thread tape to stop them from leaking - not happy
ill try goodridge or PMU lines instead next time i think
Raising a old thread, but it will be useful for people in the future..
Anyone know what the QFM HPX part number is for a preface lift 2004 cl9 is?
Also the brake pad measurements may be useful.
Ah if no one can answer that right away, I do have a set of those exact pads ready to go in at home (will be like 4pm when i can find out but!) hopefully someone has them faster to help out but!
That would be good!
Tho i just got off the phone from QFM appreantly they dont make the HPX off the shelf for my car, and i'd have to get them custom made.. But i'm sure the same size pads exist for there cars and they will fit perfectly onto the euro.
