3. Support - FAQs / Terms and Conditions
Transmission FAQ
Do you produce gears for any other makes?:
- Adhering to our strict client-confidentiality agreements, we are unable to disclose our client details
I want a custom made gearset, can you make it for me?:
- Due to the tooling costs involved with Forged Gears, we are unable to offer custom one-off gears. If you are inquiring about our OEM/ODM Development Service, please click here for further information
I have a hydro USDM B16A/Type-R tranmission, do I have to buy a JDM 1st gear kit to fit your final drives?: - We have USDM applications available which do not require the JDM 1st gear, needle bearing and distance collar
Do your gears require any special fluids or additives?:
- We highly recommend the use of our Torco Transmission Fluid when our gears are installed with a stock differential or our Limited Slip Differentials. While it is not a necessity, we observe a transmission fluid change every 2-3 Engine Oil changes. However, this is dependent on your actual mileage and frequency of usage in competition environments.
What final drive do you recommend for my car?:
- Each vehicle/driver can have very different applications, therefore in order for us to assist you with your choice, please Contact Us and we will go over all available options and help you select one that best suits you
I just installed a final drive and/or close gears. Do I have to break them in?:
- Our gears are fully finished and ready to run right out of the box. However, we do hightly recommend that an initial fluid flush be performed after 3-400miles or 1 tank of gas, whichever comes first. The use of our Torco Transmission Fluid and Magnetic Drain Plugs is highly recommended
Miscellaneous FAQ
Where are your parts made?:
- All our parts are designed In-House using the latest Solidworks 3D CAD & Cosmos FEA software, whilst the material processing is done in conjunction with our state-of-the-art overseas partner factories which utilize the latest in automated Japanese CNC and CAM equipment. All our select partners are ISO 9001 certified to ensure the highest in workmanship standards
How long have you been in business?:
- MFactory Competition Products was founded in 2004, but our staff have a collective experience of over 15 years
What kind of warranty do you offer on your parts?:
- In short, we try very hard and take pride in the parts we produce. Unfortunately, circumstances will arise that you may have received a part with a defect. Please give us the opportunity to make things right with a replacement. For more details regarding our warranty, please read our Terms and Conditions.
