Originally Posted by
VTECMACHINE
Your stock water temp gauge should move around. If it does move, you thermostat is definately NOT broken. Who told you that man?
If you were to look at a Water temperature gauge, it would go up when sitting in traffic up to around 90 degrees (in DC2R), and then when your driving depending on temperature, it will go down to sayd 75-80 degrees. Same thing applies with the stock guage on the clutser. Depending if it's summer or winter, the water temp can vary alot, and the needle will move.
Also VTEC is not a mechanism for dumping fuel into the engine.
And, not all VTEC engines burn oil... only screwed ones. My DC2R on 105,000km's doesn't burn a drop of oil - even on track days. If your burning oil, it's either PCV system, piston rings or leaky oil filter/sump plug/ sump gasket. Take the car to Honda man.
Generally if you are running VERY rich, you can tell. It's normal to blow a bit of black smoke out of the exhaust in VTEC. Not Blue or White though.
