*Now Available* MFactory Magnetic Drain Plugs
Now Available for Immediate Pick Up or delivery
Increase your engine's lifespan with the MFactory Magnetic Drain Plugs. By removing metal shavings from your oil, this will prevent premature damage and increase the life of your engine. You will notice a smoother running engine and significantly cleaner oil between changes.
Do not let your next oil change go by without installing our Magnetic Drain Plugs. Our plugs replaces your stock OEM drain plug with hassle free installation. Don't rely on your oil filter to catch damaging particles in your oil - Your oil filter alone Cannot save your engine from metal shavings.
Our Magnetic Drain Plugs come with a crush proof aluminum washer to stop leaks and utilises a neo-dymium magnet which will not rust. Beware of other cheap plugs on the market with a weak magnet.
The image to the left shows our magnetic drain plug lifting an old Cam Gear, a rear camber arm (Weighing over 1.2kg!) and 2 plugs attracted to each other through a solid 1.5inch wood shelf.
http://www.teammfactory.com/images/c...drainplugs.jpg
- Made of extra-durable lightweight Aluminum
- Neo-Dymium Magnet that Will Not Rust
- Tested to hold over 1.3kg!
- Safety-Wire hole to meet race regulations
- Extremely cheap insurance for your engine
FITMENT
MF-ENG-02 - Honda/Mazda/Mitsubishi Magnetic Drain Plug
MF-ENG-02SET - Honda Oil Pan + Transmission Set
MF-ENG-02T - Honda Magnetic Transmission Plug
MF-ENG-02SUB - Subaru Magnetic Drain Plug
MF-ENG-02NIS - Nissan/Toyota Magnetic Drain Plug
PM or Email for current pricing
Beware of MFactory copies in the market
Buy only original MFactory products from an Authorised Dealer or risk getting inferior quality products.
