hey guys sry to bring this up again..,
my laziness wont let me pick up the phone and call honda
so good people of ozhonda, how much does it cost for 40000kms service? for a CU2
shud i opt of the more expensive oil too?>
thanks in advance wuahahha
Lots. Valve clearances get done @ 40k kms.
say 750$ ?
Could be that much. Mine was around $650 from memory.
Call and find out.
40,000 km or 24 months
Recommended Servicing Time: 2 hours, 6 minutes
Inspect *
Steering gearbox, tie rod ends and boots
Suspension components
Drive shaft boots
All fluid levels and condition of fluids
Brake hoses and lines (including ABS)
Exhaust system
Fuel tank, lines and connections
Tyre condition
Front and rear brakes
Headlight, taillight, indicator, reverse light and brakelight operation
Rotate tyres
Valve clearance
Accessory drive belt
Parking brakes
Headlight alignment
Test drive (check all systems and controls)
* Inspect, and if necessary adjust
* and clean. If replacement is
* required, additional costs may be
* incurred. Replace
Engine oil
Engine oil filter
Air cleaner element
thanks alo0t :D
my cousins 40k service cost him 750 for his ciivic type are..
