Custom AP1 tail lights...Here is how I made mine
Ok you have seen many AP 1 owners modify their cars to have AP 2 tail lights. I did not want to cut up my car and I wanted some stand out tail lights so I cut up a set of AP 1 lights and fitted custom LED assemblies.
This is how I did it . Not for the feint hearted as it took maybe 40 to 50 hours and a lot of fiddly experimentation.
Obtain a set of tail lights (unless you want your car unuseable for a few weeks)
Instead of a dremel, I used a thin , flat blade like a stainless steel .2mm thickness mixing spatula and heated this to red hot in a gas BBQ camping stove. You go through maybe three cans of gas to cut through the tail lights. Be prepared to breathe in a bit of toxic fumes.
http://i850.photobucket.com/albums/ab65/twofake/2.jpg
These show the light sections removed after about 5 hours of plastic melting
The clean cut assembles are put aside and the electronics are then made to fit the red and clear lenses
http://i850.photobucket.com/albums/ab65/twofake/3.jpg
it is important to cut around the mounting points so that the completed tail light can be fitted back to the S2000 once completed
http://i850.photobucket.com/albums/ab65/twofake/4.jpg
I used plywood to make circular cut outs
http://i850.photobucket.com/albums/ab65/twofake/11.jpg
The stop/tail board is 113mm and the reverse/indicator board was 109mm
As you can see, here I just drew circles, then cut many holes, inserted the LEDs so that the polarity is all matching and then soldered them all in series.
http://i850.photobucket.com/albums/ab65/twofake/12.jpg
After a lot of trial and error, I decided that I wanted the park or tail light to be just a ring and when the brake is depressed, the outer ring lights as well as a horizintal bar PLUS the whole thing goes a lot brighter.
http://i850.photobucket.com/albums/ab65/twofake/14.jpg
This shows the testing with the stop lights on
http://i850.photobucket.com/albums/ab65/twofake/16.jpg
park lights in the housing
http://i850.photobucket.com/albums/ab65/twofake/17.jpg
Stop lights in the housing
http://i850.photobucket.com/albums/ab65/twofake/18.jpg
For the reverse LEDs I used in each assembly, three one watt LEDs that I cut out of LED downlights
http://i850.photobucket.com/albums/ab65/twofake/15.jpg
A bit of electronics was used to work out LEDs in series and constant current power supplies were made on veroboard (along with Diodes to allow same LEDs to have different currents and relays to switch different sequences of LEDs)
http://i850.photobucket.com/albums/ab65/twofake/20.jpg
Black tape was used to isolate the indicator from the revrse and to also limit the orange LEDs when they are illuminated
http://i850.photobucket.com/albums/ab65/twofake/7.jpg
http://i850.photobucket.com/albums/ab65/twofake/9.jpg
http://i850.photobucket.com/albums/ab65/twofake/10.jpg
wiring was worked out
http://i850.photobucket.com/albums/ab65/twofake/21.jpg
The original plugs were wired to the new electronics and the boards were fixed in place. This is difficult to get the LEDs centered as the original red and clear diffusers do diffract the LED light somewhat . In the case of the stop/tail light LED board, you may see in the photo that the board is mounted slightly off center so that when it is viewed from the rear, it is centered.
http://i850.photobucket.com/albums/ab65/twofake/23.jpg
Reverse/Indicator board placed in housing and fixed in place
http://i850.photobucket.com/albums/ab65/twofake/22.jpg
Stop/Tail light board placed in housing and fixed in place
http://i850.photobucket.com/albums/ab65/twofake/23b.jpg
both boards fixed in place
http://i850.photobucket.com/albums/ab65/twofake/24.jpg
Electronics are insulated and packed into the light assembly before they are reassembled
http://i850.photobucket.com/albums/ab65/twofake/25.jpg
This shows one unopened tail light and one that has been reassembled. The reassembled one looks almost untouched.
I think the hot knife method makes a finer cut.
Please remember that in some places, the plastic is almost 1 cm thick so the hot knife needs to be red hot.
http://i850.photobucket.com/albums/ab65/twofake/26.jpg
This shows a completed custom tail light and the original tail light. Note the black tape around the centre indicator. This , in my opinion, gives the centre indicator so depth when it is not on.
The assemblies were sealed along the cut lines with silicone. Please remeber that the clear section of the tail lights was never removed so the tail lights will be the same water tightness as original.
On my first light I did not cut as much as my second one and this was my mistake. I cut so much here that the red diffuser actually fell through. The only way i could get it back in was to push out the white diffuser and then attempt to push the red one back in and then the white one is easier to pul back in. Not a good sitution there so try and avoid this dilemma.
http://i850.photobucket.com/albums/ab65/twofake/27.jpg
Old on right and new on left
http://i850.photobucket.com/albums/ab65/twofake/28.jpg
new indicators and tail lights
http://i850.photobucket.com/albums/ab65/twofake/29.jpg
New reverse and stop lights
Oh , one other thing, when changing incandesent bulbs for LEDs, the indicator relay senses that the bulb is missing so there is a chance that the flasher will run too fast. I then had to either change the indicator relay or place a hidden bulb somewhere so that the car still thinks the bulb is there. I ran wires from each indicator and placed two small power diodes so that each indicator does not light the opposite side and then joined them to an old stop light bulb which I have simply placed somewhere inside the trim. This makes the indicators flash at the normal rate.
Well, just had to share this with you all. Damn lot of work and it is really easy to start and lose motivation but the end result is a exact fitting set of tail lights with custom LEDs and patterns.
I hope this inspires more out there to have S2000s that stand out and experiment until the desired outcome is achieved.
