damn man just converted my SRI back to CAI and can tell the car is alot smoother but throttle response has decreased, but nice shrill sound when revving.
I'm looking to buy a sri from ebay which comes complete pod filter. My question is: Can I only install the sri without having a cai system?
Eventually I'll do CAI but for now I'll start with sri, but just wanted to clear this up first. thanks ;)
i dont get it, when u install an intake, u either have a SRI OR a CAI, u can't have both, unless u got a SRI with a DIY cold air feed.... is that wat u mean
Yes, I should have made reference to this thread to make it more clear... http://www.ozhonda.com/forum/showthr...ight=resonator
Cool, thanks for clearing that up!
i don't give a f*ck what 3/4 of ricers may think. extended ram pipes is completely useless. think about it... your extending the pipe. you loose response immediately. only thing that works for n/a cars is shortening the intake pipe as much as you can. usually relocate the battery to the boot. then pod filter enclosure along with a cold air feed. pod filter must be high flow. usually resulting in poor filteration. theres always a compromise between filteration and flow.
You're pretty wrong. A well design CAI will tunnel the air and give it much more velocity. You will lose response slightly going to a longer pipe of course, but when you're talking about 15-20cm of extra pipe on a system that can be like 100cm long, it's pretty trivial, especially when the air is travelling faster in the CAI.
yow fellaz just a quick question about this thread, does the size of the pipe matters? like 3inch or 2.5inch?? does is make any difference? thanks :)
great info guys, my euro has a k and n typhoon short ram with cai extention, i think i may now use the cai after hearing this good exlpanation. cheers!
