DC5 fuel filter replacement (with Pics)
Hey Guys, seen a couple of people talk about this topic, so i thought i would show everyone how to do it WITHOUT a honda special tool.
Note: this was demonstrated on a Integra Type S
Aim: Fuel Filter replacment (part of 80,000 klm service)
Required: 10mm socket and ratchet (quarter drive ideal), Phillips head screw driver, hammer and flat blade screw driver/ or small pry bar.
Steps: refer pics
Other comments
remove rear seat (lower section) 10mm bolt and 2 clips
http://a6.sphotos.ak.fbcdn.net/hphot..._3913373_n.jpg
http://a8.sphotos.ak.fbcdn.net/hphot..._3443616_n.jpg
To remove seat from these clips simply pull straight up (once 10mm bolt has been removed).
http://a4.sphotos.ak.fbcdn.net/hphot..._4026219_n.jpg
Remove metal cover and harness plug
http://a7.sphotos.ak.fbcdn.net/hphot..._6257703_n.jpg
Remove these 4 screws to get to harness plug and fuel connection
http://a2.sphotos.ak.fbcdn.net/hphot...7_739578_n.jpg
Harness plug
http://a6.sphotos.ak.fbcdn.net/hphot...0_202681_n.jpg
This is what you should be left with!! to remove fuel connection squeeze clip and pull on fuel line
http://a1.sphotos.ak.fbcdn.net/hphot..._4132635_n.jpg
Gently tap the Black retaining nut counter clockwise, untill it can be undone my hand, be carefull not to cut yourself as the metal edges are sharp, i use rags to avoid this, as shown.
http://a4.sphotos.ak.fbcdn.net/hphot..._6531360_n.jpg
This is what you should be left with once out of the tank, be carefull when removing not to damage the fuel level sender unit. You can also see the new filter on the left.
http://a2.sphotos.ak.fbcdn.net/hphot..._1176054_n.jpg
Another angle
http://a8.sphotos.ak.fbcdn.net/hphot..._5923639_n.jpg
Undo the pressure reg fitting (note 2 orings are supplied, these are slightly different sizes)
http://a1.sphotos.ak.fbcdn.net/hphot..._6271918_n.jpg
http://a2.sphotos.ak.fbcdn.net/hphot..._4086277_n.jpg
remove the 2 connectors on old unit
http://a3.sphotos.ak.fbcdn.net/hphot..._7454329_n.jpg
remove this pin from housing, be carefull not to snap this, I have seen it done before!!
http://a7.sphotos.ak.fbcdn.net/hphot..._2833558_n.jpg
Swap the black sealing ring, and fuel connector clip, Also remove hose going to pump, similar clip to pressure reg (make sure these are on properly when re installing them, or they will blow off under pressure!!)
http://a5.sphotos.ak.fbcdn.net/hphot..._2620065_n.jpg
This is not a complicated job, just make sure you carefully look at the assembly before dismantling it, and make sure everything goes back into its original location.
To reinstall this unit, it is just reverse order of removal, If you are not 100% sure about doing this, then best leave it to a mechanic or confident friend ;)
good luck!
