Hi
Anyone know if the EK seat mounts holes will fit directly into a DC2? I not talking about seats or seat mount types, just the bottom bracket. thanks
Hi
Not exactly.
3 out of the 4 bolts will line up.
ok thanks. Another question then, if I get USDM PLM rails, I know the driver and passenger sides are opposite, can I just swap them around - i.e use the drivers in the passenger and passenger in the drivers side and they would work?
US/non-US doesn't matter, the floor pan is still the same.
You'll just be using their "driver side" as your passenger side, and their "passenger side" as your driver side.
Use swap inner rails technique. I used this technique to fit dc2 seats in ek.
4/4 bolts line up
if you look at rails, you'll see the inner rails don't line up, what you do is use the ek inner rail with the DC outer rail and 4/4 bolts will line up.
