DC2R Front & Rear Sway Bar Install
Hi All,
Currently in the process of installing DC2R front and rear swaybars into my EG5.
Exactly which parts on both bars require grease? I know the big D bushes need them...but what about the endlinks? The bolt that goes to through the bar and the bolt that goes through the LCA....do i need to grease the bolts that sit within the metal tubing?
I'm also installing a Function 7 subframe brace. Should I strip the paint back to check for any subframe damage/cracks from the previous swaybar? Or is general cleaning around the contact areas more than enough?
Is it absolutely necessary to torque the bolts? As I don't have a torque wrench.
