Civic fd1 2007 rough start and idle
Hey guys,
so last week my 2007 civic overheated and i found the radiator was leaking, I've replaced the radiator, thermostat and cap, filled coolant and bleed the system,
took it for a drive and after 15 min or so when i parked it started misfiring and having a hard start, no CEL on, no codes, tested compression in cylinders and found 120,125,130,140. sparkplugs look ok, disconnected each coil separately and found to be working, any more "cheap options in mind before i'm trying plugs and coils?
Thanks, Roy.
