If it came on once, then do th test and check the code. You will have to reset the ECU to get rid of the code :)Quote:
I just got my car back from the panels.
While driving sometimes the engine lights go on. other times I don't.
I didn't have this problem before. what could it be?
check your computers for codes
could be anything.
ecu will get you started in the right direction
i got a code
19 Automatic transmission lockup control valve
what is that?
where is it located and what does it do?
its located on the Auto transmission.
you will find 4 solenoids on the outside, front of the tranny
shift A & B
AT Lockup A & B
the PGMFI ecu locks up the torque converter at certain RPMs and speed using these two solenoids.
hey.. i have engine codes 15 and 9.... car has engine lights on when driving.. and sometimes chugs a bit.... any1 have any ideas? eg si btw..
thx
dahm
code 15 is a bit of a bitch to diagnose
code 9 is CYP Cylinder position sensor.
just a guess but your dizzy may be on its way out
jebus... yeh.. thought it might be the dizzy.. it was making squeels... then.. later.. knocking on the cover...
yeah your dizzy is rooted
the bearing has failed, the CYP pick up is hitting the sensor
next she will seize up
thx for the help mate
much appreciated...
nice DIY..
Just did the ECU check
it code 43 Fuel supply system
so could it be the O2 sensor
or the Fuel Filter or Injectors?
I have no idea :confused:
