Eletrical problem with my keys ???
hi all...
i have been having trouble with my accord recently 95 CD5..
The problem is most definitely Eletrical..
Once i was driving on the freeway and i realized that my Speed o Meter and Rev meter just died, like the needles fell straight to zero really fast....the engine might have turned off but i did not realize that because i have a manual.
everything on my Dash turned OFF CD player and clock was running fine music was uninterrupted...all this happened probably for a max of 3 secs then everything came back...
NOW the car in on my drive way and i know what the problem is but dont know how to fix it...
The problem is the Place you put the key when you go to start the car,
The key has 4 positions.OFF, ACC, ON, CRANK..
When i twist the key in the ACC everything is working like radios et, But when i put the key to the ON position nothing happens, it feels like it is still on ACC but it is not...
When i turn the Key half WAY between ON and CRACK then all the Dash lights come on fuel pumps working etc like it was in the on position.
Then i Crank the car and start it it starts but as soon as i let go of the key it springs back to the on position and everything turns of engine turns off no lights on dash etc cd still working though...
Now what i have noticed is that after starting the engine i let the key spring back half way between ON position and Crank everything continues to run etc just like normal ...
so the problem is that the ON position of the key is not working...
any help is greatly appreciated..
