Another strike for ultratune. Ruining a perfectly good set of pads.
If the rotors were glazed, just run some 80 grit sandpaper over it. That's why I do each time I replace a set of pads.
Hi all, just an update again. So I had no luck. The mech refinished the front pads with the QFM's and reapplied paste. This minimised the squeel but I ended up with a rust ring around the rotor where is wasn't contacting the pad. We had the QFM chemist on the phone, and in the end, we swapped them for a Mintex pad of the mech's choosing.
These are a softer compound and the rust ring was fixed, but they squeel again.
So six months and few k spent, and I still have problems.
I found this TSB: http://ww2.justanswer.com/uploads/lo...51_a09-096.pdf
It introduces some V springs but it's a US TSB. The part number is valid but not sure if it will work on my accord. Pretty sure an EX will be fine though.
So sick of this, just want brakes that don't squeel.
