Only bulb size with hi/lo option is H4, which is in the standard EG/EK lights.
All other types are single beam.
hi, more pics of your angeleyes please im looking 2 buy some :p and where did you buy them from?
hi i repeat my question :p
sorry dood, yeh pretty much easy found over ebay :)
also on a 2nd note after driving with these for a while the low beam hids are brilliant in driving conditions however the High beam MTEC 4750K hid halogens are terrible! even at 100watt extended! just dont seem to be very bright or have a good range!.... will deffinately be ripping them out and sticking the factories back in!
Just use a set of non-coated globes, the coating removes the increase in wattage to make more colour. If you use a higher wattage non-coated globe it will certainly be better.
really? how do you remove the coating?
get sum front on pics happnin yo!
hey there nice setup, i was just wondering if you had any trouble with your projectors with the hids, because i have heard that the hids can melt the housing of the headlights, have you have any problems whatsoever with the projectors and the hids. ?
hey dude how much did that kit set you back ?
