Thanks Fred.
Its the same as mine, purple Pivot Mega raizin.
I have decided to also replace the smaller middle capacitor with the 6800uF. So all 5 capacitors will be the same. It will be a tight fit but should fit. Once finished it will be 34 mF an upgrade from the original 21mF. I don't know if this will be noticeable.
Fred, can you please tell me the voltage (low and high) registered on your mega raizin.
Maybe I can use this information to compare if the upgrade makes a difference or not (yes I should have done a before and after, but its too late now).
So I have been running the upgraded raizin for a couple of months now and I think it's good. The voltage reading is 10.7 V and 15.1 V when I started it a few days ago. Slight idle rev drop when I put the windows down seems to have disappeared. Fred, can you please tell me what the voltage reading on yours are? I should have taken some measurements before I did the upgrade.
Nice stuff there Martin. I'm a big fan of the mega raizin.
What happens when you hit 88MHP?
