[How To]Installing V3 Triton Rear blinkers for FK/FN
How to install V3 Triton Rear blinkers for FK/FN
What you will need
VLED V3 Triton Amber LED system
Small hands
A Phillips Screw driver.
A torch
Adhesive Thermal tape
If you want to add the triton rear blinkers you will need the following.
The V3 Trion system.
The Base you will need is 7440/7443
1: Start by removing the control box and installing the base connector(note: if the model does not work, rotate the base connector 180°)
http://i662.photobucket.com/albums/u...Tritons/14.jpg
2: Remove the screw cover and then remove the screws for the rear housing.
http://i662.photobucket.com/albums/u...Tritons/15.jpg
3: Insert the LED module into the connector.
http://i662.photobucket.com/albums/u...itons/16-1.jpg
4: Install screws to match the tabs on the connector
http://i662.photobucket.com/albums/u...itons/17-1.jpg
5: Install the thin narrow gasket.
http://i662.photobucket.com/albums/u...itons/18-1.jpg
6: Add some thermal transfer tape to the control box and add a fuse to the load resistor fuse holder.
http://i662.photobucket.com/albums/u...itons/19-1.jpg
7: Clean the metal behind the bumper with some IPA and stick down the control box.
http://i662.photobucket.com/albums/u...Tritons/20.jpg
Before
http://i662.photobucket.com/albums/u...Tritons/21.jpg
After:
http://i662.photobucket.com/albums/u...ritons/21a.jpg
