we refer to the first timer here , ie MUZZ :)
Hehe, i used the last band aid after cutting myself stripping the interior yesterday lol.
muzz let me know how the groudn control feels :thumbsup: might get that sometime down the track but for now sticking to my eibach's :D
I've been looking at some coilovers by PIC Performance, which has received some good reviews over in the states, all up it looks like its going to cost me around AUD$1,000 shipped.
Has anyone heard of these?
Wear gloves - seriously...
Tips:
1) Watch for the recoil when taking out the springs
2) Observe where the washers go - Koni's usually provide new washers, use them.
3) Watch that you set the correct perch height on the Konis
4) If it doesn't bolt it, don't force it...you probably have the angle wrong. Take out and redo.
5) Tighten the top bolt last, so you can adjust the angle of the shock and when tightening the top bolt, load the shock and spring.
Are you using Koni's at all?
good luck
Well, not really...for Double Wishbones, the alignment isn't really that affected as compared to a mcpherson strut ehrn you swap shocks.
If you drive it now, you'd probably find the alignment to be OK. Seriously, I've been swapping between shocks and have actually never gone for a wheel alignment, well, I'll just check the toe and camber myself with a string and ruler but they seem quite stable.
forgot to mention that i also installed a camber kit :P
so everything is out and the car goes nuts on the road lol
*Agrees*
ive gone thru about 6 different varieties of shock combos over teh last few years and never had a alignment done. Only , because the HEIGHT remainded the same/similar.
IF you drastically alter the ride height OR have hit a few potholes or bumps etc , its best to get an alignment to keep you TOE in spec. Saves tyres
Oooo...Camber Kits...Pics?
Here's my spherical bearing rear camber from mFactory
http://i64.photobucket.com/albums/h1...a/DSC00079.jpg
Here's one of my set of shocks
http://i64.photobucket.com/albums/h1...SHipermax3.jpg
I have a similar type at the rear - awesome adustment
http://img.photobucket.com/albums/v110/FR33K/camber.jpg
