On an AP1 2000 model S2000, where is the OBD2 DLC port? This is for an Australian model btw, not overseas.
Cheers
Cheers
We don't have OBD2
Yep just realised this, no OBD2 port, but the DLC is the same as the obd1 and early obd2 cars, its located under the driver's side dash, two pin short
Does anyone know whether Greddy Informeter Touch works on our AP1 S2k ? (I saw someone has it on his AP2 S2K in HK)
DLC ıs useless to us.. unless bıg $$$
Which begs the question, as US AP1s have an OBDII connector what is the difference between the US and Au S2000 diagnostic connectors?
Does the AUDM AP2 have OBD2 connector?
There are no AUDM AP2s. But later model AP1s have ODBII.
oh thanks!
Mine is MY00 and i believe it only has a 3-PIN DLC connector. I've been asking around to see if anyone successfully hooked up their Greddy Informeter Touch (or something similar) using a 3-PIN DLC to 16-PIN OBD2 adapter. I'm so anxious to get it to work with my S2K.. :(
let us know if you get it working. i wanted one of those or a scangauge... but yeah, no OBDII
Scanguage doesnt work. From my personal experience. (Any scanguage)
Thanks VeYzZii. What about Greddy Informeter Touch? It only takes OBD2. Do you think it will work using a 3-PIN DLC to 16-PIN OBD2 adapter?
More info: http://greddy.net.au/products/displa...SubCategory=56
thanks in advance!
