Hi can someone tell me the difference between clutch fluid, transmission oil and gearbox oil.
clutch and brake fluids are mostly same.
transmission and gearbox are same, just make sure you use the correct manual/auto.
get them from honda
Your clutch fluid is a gold yellow colour which is the same as ur brake fluid if you choose to use genuine honda fluids
Your transmission oil will be a pink colour f its an auto....and will b a brown colour if its a manual and called Manual Transmission Fluid (MTF)
Make sure when u get the fluid u know ur car is manual or automatic.
U need Clutch fluid to allow a smooth clutch in your car for lubrication etc..
And the transmission/gearbox oil Fluid is for smooth gear changes
Make sure you get your fluids from honda...don't go alternative products..hondas can be sensitive with there fluid
