honda eg door problems
hey guys my door pretty wierd atm , had alarm , alarm wouldnt even open the door or lock it, only immobiliser worked
i took the alarm out ,immobiliser everything .
the door still has same problem as before when i shove the key in and open only works on one side
eg. open using key driver side only driver side opens passenger doesnt .
also the driver side when i press the lock button it locks only driver side dorsnt look the passger .
so basically to sum it up each side works for it self. any one got idea how to fix it ? i searched no luck .
passenger side central lock actuator is stuffed
same problem as my mates car, can anyone get pics of the central lock actuator ?
I had a similar porblem (my driver's side actuator was stuffed). Go down to Jay car and get yourself a new actuator, I think i paid somewhere around $11 for a master actuator 4 wires if it's your drivers side one, or get a slave 2 - wires if it's your pass side one, pretty straight forward to install, one you see if you'll figure out how it goes in
i have them but then for some reason the guy did it like cut wires and twisted together LOL
driver side is 3 wires and passenger is 2 wires
ill get pics now !
my one just needed a clean, use some wd-40 to loosen the mechanisms up once you've installed the actuator.
that thing ur talking abt is this black thing ? http://i636.photobucket.com/albums/u...o/IMG_0991.jpg
i need on both sides ? seems like i got none lOL
this happen to my car too about 4 or 5 months ago
how exactly do i fix it?
alright heres the master
http://www.jaycar.com.au/productView...r&form=KEYWORD
heres the slave
i gotta buy both ?? theres no wirings included .
edit i got a master one already like the picture from my alarm
has 5 cables ! just like the master picture .. but i only got 3 cables .. how do i connect em ??:eek::confused:
Yeah that black think in the picture (but it should be screwed into the door not zip-tied)
Not too sure why your wires are twisted together mate
When i did mine i just used the sme wires coming form my alarm and took the old one out and put the new one in the same way (on my EG)
If your alarm was removed, maybe they removed the control module as well. I recently installed remote central locking in my EK CXi (no central locking). Got the whole kit from WOW on special for $100, so if your alarm has been taken out by some n00b and they didn't tell you what goes where and which wire is which might be a good idea to start form begining.
Also your 3 wires will most likely be
Lock trigger
Unlock trigger
and Ground
the other 2 wires on the master go to the slave to send the signal if you wire them in parallel (i think, not 100% sure) i just left them taped up
LOL the noob that remove the alarm was me hahaha
cos the job was ****in dodgey as it didnt even work .. i dont think the electricity for that part works ..
do you know which wires i connect to so the motor in the master works ?
