Brake Boosters, Master Cylinders, DIY Upgrade Reference Guide
OK. I am requesting everyone's assistance in creating a Master DIY Reference Guide to Brake Boosters and Brake Master Cylinders.
My research so far reveals -
There are at least four Brake Master Cylinder sizes as follows:
13/16"
7/8"
15/16"
1"
There are at least six models of Brake Booster as follows:
NM205V
NM230V
NM240V
NM260V
NM280V
NM290V
Each of the above has variations. For example:
NM205V-1 & NM205V-3
Some have GREEN labels and some have RED labels. There are also YELLOW labels. These are located on top of the Brake Booster, usually manufactured by NISSIN but there may be variations on that too!
Brake Master Cylinders are also manufactured by NISSIN. The size of the BMC is on the shaft usually underneath the Fluid Cylinder. There are, however, some generic units that don't have the size.
I will compile a chart to be made available to everyone here when I have finished collecting responses.
What I'm compiling is a Reference Guide.
Booster Model
Colour of Label
Manufacturer of Booster
Brake Master Cylinder Size
Manufacturer of BMC
Honda Model
Year of Manufacture
Other Info/Notes
The object of this guide is to assist in brake upgrades so at a later date I'll be adding Brake Caliper information (sizes, pads, etc)
If you would like to contribute, next time you go out to your Honda make a note of the above information and post it here. I'll add it to the Guide. If you can take a clear photo of the Brake Booster label and/or Brake Master Cylinder that would be appreciated (but not essential).
Thanks,
Peter
Here's what we will end up with
Booster - NM205V-1
Red label
Master Cylinder - 13/16th
Manufacturer - NISSIN
Honda - CRX and Civic 19876, 1988-90
Booster Model NM290V
Colour of Label no label, stamped on
Manufacturer of Booster Nissin
Brake Master Cylinder Size 1"
Manufacturer of BMC Nissin
Honda Model DC2R
Year of Manufacture 2000
ABS? - Yes
Other Info/Notes - flare nuts 10mm front and rear
Attachment 25880
