B-series engine application
hey guys found this information thought it mite come in handy to some people..couldnt find this on ozhonda so thought i would chuck it up.
It shows which b-series engine is in what honda, i think its from an american site so may not b 100% fit with AUDM.
If anything is missing let me know and i can add it.
Credit goes to answers.com
frahmy.
ps. wasnt sure if it belongs in this section..if not mods please move to correct one.
B16
B16A
Note: All JDM B16a engines are marked as 'B16a' (with no number to identify version).
VTEC
Found in:
1989-1993 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1991 JDM Honda CRX SiR (EF8)
1989-1991 JDM Honda Civic SiR/SiRII (EF9)
Displacement: 1595 cm3
Compression: 10.2:1
Rod/stroke ratio: 1.74
Power: 158 hp @ 7600 rpm & 112 ft·lbf @ 7000 rpm
Transmission: S1/J1/Y1/A1
1991-1995 JDM Honda Civic SiR/SiRII (EG6/EG9)
Compression: 10.4:1
Power: 168 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
Transmission: S4C
1992-1995 EDM Honda Civic VTi
Power: 158 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
1992-1996 JDM Honda CR-X del Sol SiR
Compression: 10.2:1 / 10.4:1
Power: 158 hp - 170 hp & 111 ft·lbf - 116 ft·lbf
B16A1
VTEC
Found in:
1989-1991 EUDM Honda CRX 1.6i/VTi (EE8/ED)
1990-1991 EUDM Honda Civic 1.6iVT (EE9)
Compression: 10.2:1
Power: 160 hp (117 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
B16A2
VTEC
1996-2000 Honda Civic VTiR (EK)
Compression: 10.4:1
Power: 160 hp @ 7800 rpm & 113 ft·lbf (153 N·m) @ 7300 rpm
1999-2000 Honda Civic Si (EM1)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21 S4C
1996-1997 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Power: 160 hp (119 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
Transmission: Y21
B16A3
VTEC
Found in:
1994-1995 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Transmission: Y21
B16B
VTEC
Found in:
1997-2000 Civic Type-R
Compression: 10.8:1
Power: 185 hp (137 kW) @ 8200 rpm & 118 ft·lbf (160 N·m) @ 7500 rpm
Transmission: S4C WITH LSD
B17
B17A1
VTEC
Found in:
1992-1993 Integra GS-R (DB2)
Displacement: 1678 cm3
Compression: 10.0:1
Power: 160 hp @ 7600 rpm & 117 ft·lbf (159 N·m) @ 7000 rpm
Transmission: Cable~ YS1
B18
B18A
Non-VTEC
Found in:
1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
1986-1989 Accord EXL-S/EX-S (Japan)
1986-1989 Vigor MXL-S (Japan)
Displacement: 1834 cm3
Compression: 9.4:1
Dual Keihin Carbs
Power: 130 hp (97 kW) @ 6000 rpm & 120 ft·lbf (164 N·m) @ 4000 rpm
Transmission: A2N5, E2N5
This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
Non-VTEC
Found in:
1990-1993 Integra RS/LS/GS (DA)
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Power:
1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
1992-1993: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
Transmission: YS1
B18B1
Non-VTEC
Found in:
1994-2001 Acura Integra "RS/LS/GS" (DC4)
Displacement: 1834 cc
Compression: 9.2:1
Bore: 81 mm
Stroke: 89 mm
Power:
142 hp (104 kW) @ 6300 rpm & 128 ft·lbf @ 5200 rpm
Transmission: S80
B18C
VTEC
Found in:
1994 Honda Integra SiR-G
1995-1997 Honda Integra SiR
Power: 180 hp (128 kW)
1997-2001 Honda Integra (Japan) Type R
Power: 200 hp @ 8100 rpm
B18C1
VTEC
Found in:
1994-2001 Integra GS-R (DC2)
Displacement: 1797 cm3
Compression: 10.0:1
Power: 170 hp (127 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
Transmission: Y80
B18C2
VTEC
Found in:
late 1993-2001 Integra VTiR (DC2) (Australia)
Power: 127kW@7300RPM
Torque: 173Nm@6200RPM
Weight: 1,176kg
B18C3
VTEC
Found in:
1995-1998 Acura Integra Type R
Power: 195 hp
B18C4
VTEC
Found in:
1996-2000 UK Civic 1.8i VTi Acura Integra
Compression: 10.0:1
Power: 169 hp (124 kW) @ 8000 rpm & 129 ft·lbf (174 N·m) @ 7500 rpm
Transmission: S9B
B18C5
VTEC
Found in:
1997-2001 Integra Type-R
Compression: 11.0:1
Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (176 N·m) @ 7500 rpm
Transmission: S80
B18C6
VTEC
Found in:
1998-2001 Honda Integra Type Rx
Power: 200 hp (149 kW), 136 ft·lbf
B18C7
VTEC
Found in:
1996- Honda Integra Type R (Australia)
Power: 210 hp (149 kW), 136 ft·lbf
B20
The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
B20B
VTEC
Found in: Honda CR-V, Honda Orthia
Displacement: 1973
Power: 180 hp @ 6400 rpm
Torque: 155 ft·lbs @ 5300 rpm
Compression: 9.2:1
Bore: 84 mm
Stroke: 89 mm
Redline: 7000 rpm red line
B20Z
NON-VTEC
Found in: 1999-2001 Honda CR-V
Displacement: 1974
Power: 170 hp @ 6200 rpm
Torque: 140 ft·lbs @ 4500 rpm
Compression: 9.6:1
Bore: 84 mm
Stroke: 89 mm
Redline: 6700 rpm
B20A/B21A
The B20A and B21A are not considered to be 100% part of the B family. See Honda B20A engine
