:thumbsup:
:thumbsup:
That is the main concern with the B20A6, I have built a fully forged one in the past and that was very expensive to source parts for however not impossible. The same can be stated for the Mitsubishi engine but givens its size, presents an interesting option. It is an interesting point of discussion, because if you could fit any engine into the front of a EG Civic, what would be the best? Ideally I would like to stay FWD as going RWD would take up a lot of underbody aero advantages that the FWD layout presents.
Out of the options you have mentioned, a K24/K20A FWD setup will be the best for the SMSP track without a doubt.
I would imagine any money saved by using an old prelude engine or non-honda unit will need to be used for all the custom work anyway. Remember that you're comparing engines/transmissions that have no off the shelf conversion parts (for an EG) to ones that have everything you need already developed and readily available.
I'm sure you know about the EG that JDMyard won open class with this year, that is a good example of what can be done this way.
It is definitely an interesting point of discussion and given this will be the first time this car has run and the main focus being on aerodynamics and weight, the powertrain will probably end up being a B18 or a K24 but considering all the available options is something I am really keen to do. And powertrain has a long wait ahead, more updates on the wide body progress tomorrow.
Holden 186?
Struggling to work out whether this thread is serious or a piss take.
If your doing something this extreme and open for suggestions.
4G63 from EVO 8. My EVO 9 put down 258kWs on mostly stock car. DW300C + ID1000s + 3in exhaust turbo back only budget spec MRT lols + BOV + 3port boost controller + Pipe from turbo out to intercooler on e85.
Similar Deck height and use of transverse gearbox should make for an easy swap if Track car.
Precision Auto do 800hp builds for for under 14k Long block - Fcuking bang for buck. I have spent similar on my ej257 and im only at 400hp.
https://precisionautomotiveracing.co...ges/evolution/
Again Idunno your budget and if your looking to place to top 10 at WTAC i think your gonna need heaps of power + reliability.
With about 20K you already be at power levels of big hitters of WTAC with reliability.
No updates over the weekend, personal life got really busy and I ran out of body filler. Probably won't get an opportunity to work on the car for a few weeks now with work commitments but plenty of parts to be order so will be getting some new goodies.
A few goodies have arrived, bit of work to do be done before these can start to get ready for mounting.
Attachment 30204
Attachment 30205
Edit: How do I rotate these images hahaha ;)
Nice sheet lol
