I've recently install a JDM Mugen N1 ECU in my AUDM DC5R, it will start momentarily then cut out. I believe it has something to do with the immobilizer.... Does anyone have any information on how to fix this problem?
Cheers.
Cheers.
i would have thought if it was an issue with the immobilizer then it wouldnt start at all - unless its an aftermarket one like a 3 or 4 pt one
do you have a fuel kill switch?
It could be the immobilizzer it senses every thing is working fin the goes oh sheeeeeeet not the right ecu power down. Go to honda to get your immobilizer reprogrammed to that ecu
The JDM ecu doesnt have an immobiliser. You will need to ground the fuel pump wire located on E1.
