guage only show you when your car running risk but don't need to if you don't like this
Pretty sure you need the gauge as that's the controller
http://www.ozhonda.com/forum/showthr...=1#post3839254
Have a read of that thread as well
If you aren't getting the car tuned you can install it as a secondary O2 simply to feed data to the gauge. If you are getting the car tuned then definitely replace the narrowband with the wideband, wire it into the gauge/controller AND the Hondata unit/ECU. It's only one wire to the ECU normally, and it should just go to the pin that the stock O2 signal wire runs to. It'd be a waste not to get proper use out of it or see the benefits of running a wideband in the first place.
I am getting it tuned. My tuner has wideband but it is only tailpipe sniffer. Is it worth spending 200+ for a little bit more accuracy or will the tailpipe sniffer suffice?
Strongyl recommend getting it if tuning
