ABS light staying on ek cxi
So my abs light usually comes on for a few seconds before turning my car on but now the abs light is staying on while I drive. I've check for malfunction codes and got a code 11 (drivers side abs sensor). When checking the malfunction code it will only do it once instead of repeating code over as usual. I'm confused as the cxi does not come with abs. So far I've rest ecu, checked brake fluid. Should I just remove the bulb behind the cluster? Or is there something else I should do??
