Sweet yeah i think its okay aswell.
I had already done 370kms with less than a quarter left on the gauge. So i put a full tank in again.
It showed 29 litres on the petrol station pump meter when it stopped, so im assuming i still had about 11 litres left.
EM1's are a 40L tank is this correct?
But im still getting some black carbon on my rear bar :(
just a tiny amount, when i swipe my finger on the rear bar, its just annoying thats all hahah.
Maybe its a white car kind of problem LOL
Thanks guys
No its not... I've owned 2 EM1's. I avged 350KM per tank was i was hitting Vtec every 2nd corner.
Normally got approx 500KM per tank.
Okay
Highway driving aswell?
When you fill up how many litres did it say on the pump meter?
I was assuming i was okay because i still had 11 litres left and had already done 370kms?
Thanks
Yeh Mixed of all sorts.
I work 24 hours and drive all sorts of roads. Minimum 50KM per a day.
From memory it was approx $50-$60 per tank which got me 500KM+ per tank if driven civil.
Okay.
I just checked my spark plugs and they are still fouled with carbon.
Ill probably change my thermostat.
Will scanners be able to see what is causing the problem?
Thanks
Where would you guys recommend to go?
For a scan, to see if its running rich and what would most likely be causing the problem.
I scan tool would not be able to pickup what's causing the problem unless you have a check engine light.
Have you tried running some Subaru upper engine cleaner through the motor yet?
Also check valve clearance
How long you had the car, was it like that before ? when did the problem occurred?
Try to use Fuel injectors cleaner.
I have a feeling Crayan maybe on the money with this one.
