The engine is generally removed from the vehicle and completely pulled apart. The block needs to be bare to be bored and honed..
There's heaps of info around the web on rebuilding engines. I would advise doing some reading..
Would advise not to advise lol
Have read heaps but I have questions,do you mind if I ask?
No bore and hone,just replace pistons only.Have seen it done.
My question is if I replaced the pistons now would that avoid a bore and hone or you should do them both really anyways.
Just give em a quick rub with 180 grit, she'll be right
LOL there's ALWAYS one isn't there.
Now,instead of Google searching it,I'm gonna ask another question super-man.Just to give you a good ol' laugh :)
Hone-ing lol doesn't mean you need over sized pistons? But how do you really know if it requires a re-bore?
Dafuq are you on about?
I'm saying that new piston rings need a honed cylinder wall to break-in.
You are telling me that it's possible to simply fit a new set of pistons and rings without any machine work.. Can you also explain to me why you would do this, knowing that your piston rings won't break-in properly?
I'm gonna do this next time I do a rebuild. Good info in hear.
Cheers gotcha.How do you know if you need a re-bore though? Inspection and measurement?
Nice link :) hehe
Yeah Have to inspect and measure.
There's no point in replacing pistons only. If they are worn out of spec or failed then you will need a bore and hone anyway at the least. You also will need to ensure correct piston to bore clearance then as super-da9 says the honing is important for bedding in the rings. While it's out you would at the minimum replace the bearings as well, clearances have to be checked at the same time the crank may need polishing or linishing of the journals.
There's many things to check when the block is apart, it really needs full inspection before reassembling anyway. The cost will always be more than you think, if you do all the removal, tear down and reassembly yourself I'd guess prices around the 3k mark once you factor in all the consumables/gaskets/seals etc that would be needed. That is for a cheap build too without any fancy brand name parts bumping up the price.
Only if cylinder walls are damaged.
This video has a description of parts changed and why.Also swaps em' out from UNDER the car.
https://m.youtube.com/watch?v=KmdpRxWq7gA
