Braided Brake Lines.. ADR?
I've been doing some research on braided brake lines. It's been confusing to say the least.
From what I've heard before the braided lines needs to meet an ADR 7, which means it needs to have a ADR approved sheaths, something to do with a "Whip test" of some sort.
But that apparently had been superseded by a ADR 42 subsection 15
Quote:
15. BRAKE TUBING AND BRAKE HOSE
Flexible hydraulic brake hoses, air or vacuum brake tubing and air and
vacuum hose, flexible and hydraulic power hose between the Brake
Power Unit 31/00 or Brake Power Unit 35/00 and the master cylinder
or its equivalent must conform to SAA, SAE, BS, JIS, DIN, ISO or ECE
Standards specified for flexible brake hoses, air brake tubing or hose or
vacuum brake tubing or hose or hydraulic power tubing or hose and be
fitted to the vehicle as to prevent chafing, kinking or other mechanical
damage under normal motion of the parts to which they are attached.
Hmm.. says nothing about an ADR approved sheath... or a whip test... and it seems any reputable manufacturer from anywhere in the world is ok.....
Can i get some clarification on this?
