Another note for lowering the CU2
with a "full" load the ground clearance for a CU2 is 110mm!!!! on stock suspension!
:thumbsup: Eibach springs + Progress Rsb 22mm... feels alot more planted around corners and improved braking... downside maybe alittle bumpy, but good value for money!
got it from heeltoe with coupon if your interested
Surely am..
What sort if coupon is this..?
I'm on 18 inch lux rim and the ride is already quite bumpy so I might opt with the RSB for the time being.
What endlinks are you using?
I'm about to order Progress RSB with some other stuff from heeltoe.
I want to get some suggestion what other parts should I get to save on postage.
I had a look at the Hawks HPs brake pads but I'm not sure I should replace the pads since my CU2 is only a month old.
The stock brake pads is crap but should I spend $160 on brake pads alone??
K&N Performance Air Filter, Drop-In replacement, 09+ Acura TSX CU2 4Cyl, 33-2430.
Special @ $42.35 (28% off)
TIEN STECH ($290.00) and HTECH ($305.00) as well as H&R street sport ($246.79) springs are 25% off atm.
Hawk Performance Ceramic Front Brake Pad Kit 01-03 ACURA CL, HB366Z.681
$93 (15% off) ---- 3 dollars more than the HPS, but will out last your damn Rotor... and almost no dust
Fredoops: were you watching tennis or you're normally up this late? :p
I'm still unsure about K&N drop in filter, will it void the car warranty if I change the filter to this?
And do you reckon I will better off replacing the pads now then later when stock ones need replacing? Will it void the car warranty?
I'm not planning on lowering my CU2 since I scrapped it twice after only two weeks coming out from office driveway. I know, I need to find a new job with an office that has a flat driveway.
I'm so tempted to lower it to get better handling... The dilemma.........
no it wont. its just a direct replacement to the oem one. As if u change oil brands to something better. will not void warranty.Quote:
=pitiek;3222255I'm still unsure about K&N drop in filter, will it void the car warranty if I change the filter to this?
just had my progress 22mm RSB installed onto my cu2 which has a takeda SRI, teins super street coilovers and fujitsubo exhaust.
the ride so much better and makes the tune chipped engine so much more fun to drive...
but just note they is a tiny mod to the exhaust flangers that needs to be done but does not affect the exhaust one bit.
also SRI does not void your warranty...have checked this with a few dealers and they are all fine with it.
Are you using the stock endlinks?
I will attempt a DIY sway bar install this time, so is this exhaust flange issue DIYable for a newbie???
